Hi guys,
My pc restarts a few minutes after boot,
ive tried multiple things to try and fix or identify the problem
  • Windows fresh install
  • running with a new gpu
  • changing memory
Does anyone have any other ideas?
  • windows 8 Pro 64-Bit
  • AMD FX-8150, coolermaster 725w extreme 2 PSU, seagate barracude 2TB, ASUS M5A97  R2, corsair h015 cooler, ASUS RADEON HD7770, 16GB Memoery g.skills
  • BIOS Version 2501
https://linustechtips.com/topic/331869-troubleshooting-pc-problems/
Well dose it say any thing when it turns off. Is you cooler on you CPU on good with thermal compound
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
Hi guys,
  • changing memory
  • BIOS Version 2501
I have experienced an issue like this before, the fix for it for me was re plugging in my sata cable and the power for the Hard Drive, if that does not work try updating your bios, or replugging all the cables and checking connections.
