Memory Compatibility issue! Some solutions?
Solved by Wirbelfeld,
Do you mean it'll be fine when undervolted? Or do you mean it'll work fine "plug and play"? Because running it at 1.65V is certainly not good for the CPU... no?
IT definitely wont damage anything but it might cause slower speeds
thedood2k ·
Posted in Power Supplies2 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
4
play_circle_filled
Latest From ShortCircuit:
