Looking to capture 30 fps 720p. im using a less than powerful laptop now but will be building a rather beefy machine this summer. would like a unit that could record on its own but if there is a PCI-E capture device with a better value im willing to swing that way. also the ability to livestream would be handy, but not necessary
Thanks!
-FrigidNinja-
https://linustechtips.com/topic/331066-game-capture-solution/
Elgato and Avermedia both have excellent solutions for this
(If you only want 720p30fps you can go for the regular Elgato and I know AverMedia has some PCI cards)
https://linustechtips.com/topic/331066-game-capture-solution/#findComment-4494672
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
https://linustechtips.com/topic/331066-game-capture-solution/#findComment-4499082
 i don't doubt it, but what do you think makes it the best?
(Heil GabeN, supreme overlord, may you be blessed with infinitesimal discounts)
https://linustechtips.com/topic/331066-game-capture-solution/#findComment-4502037
