Wireless connection
Go to solution Solved by kristaps552,
Try changing the wireless channel on your router when you set it at higher speeds, it could just be interfering with something.
I am using the system in my signature and an Asus PCE-N15 wireless card. For ages I have had to use a wifi connection set up at 54mbps however, this is extremely inconvenient as it restricts my connection greatly. The problem is when I set up the access point to be 300mbps even though the wireless card is rated to work at such a connection it drops off randomly. Even when working the connection is terribly slow and infact worse than at 54mbps.
Any suggestions?
So I spelt something wrong in my post... I don't care I don't read through what I write and I type very quickly.
Intel 3770k stock, MSI Z77A-GD65, MSI GTX 760, Corsair Vengence DDR3 1600Mhz 16Gb, Corsair RM 550W, Samsung 830 256Gb, some random hdds.
https://linustechtips.com/topic/331008-wireless-connection/
What router or Wireless access point are you using?>
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/331008-wireless-connection/#findComment-4493955
Need more information
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/331008-wireless-connection/#findComment-4493987
https://linustechtips.com/topic/331008-wireless-connection/#findComment-4493999
Sorry that previous reply went a bit wrong.
The router is a virgin super hub 2. I have managed to get it to my network speed of 40Mbps however within a speed it fluctuates a larger amount ranging from 5-40Mbps.
https://linustechtips.com/topic/331008-wireless-connection/#findComment-4494009
The SH2 is known to have a not reliable Wi-Fi signal at the best of times. Have you tried setting your 2Ghz band to 144Mbps?
The issues occur at all settings but 54Mbps from what I can tell.
https://linustechtips.com/topic/331008-wireless-connection/#findComment-4494175
https://linustechtips.com/topic/331008-wireless-connection/#findComment-4499456
Thanks. It would appears the auto setting on this access point doesn't do the best job.
https://linustechtips.com/topic/331008-wireless-connection/#findComment-4507896
