thermal paste question
Go to solution Solved by Enderman,
you can, but it will overheat if you do anything intensive
go buy some
Thermal paste is like 8 bucks, just go buy some.
https://linustechtips.com/topic/330522-thermal-paste-question/#findComment-4487242
go buy some
https://linustechtips.com/topic/330522-thermal-paste-question/#findComment-4487243
