I'm looking to buy a used reference gigabyte r9 290 and i wonder if it's possible if you remove the shround open the top of the fins and slap a fan on. would that work ? another posibility is using corsair h50 but have to buy kraken g10  and gpu would go into slot 2 on motherboard(p8p67pro) and my pci wireless card is in 6th slot would that fit ?
https://linustechtips.com/topic/329799-reference-r9-290-cooling-mod/
You could get a corsair HG10 and an AiO, or something like the arctic cooling aftermarket cooler would do better than removing the shroud, as it's not just that that's the main issue with it.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
the kraken G10 and Corsair H50 will barely take up 2 slots. you will be fine putting a PCI wireless NIC in slot 6.
*edit* I should say the H50 Quiet Edition... but I don't think the old version H50 even fits anyway.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
Um the Kraken G10 takes up 2.5 slots..............
Well it depends but it's definitely 2 or more
I busted out the old cell phone camera to check, yeah it would definitively be a tight fit trying to get a PCI card next to a G10. In the pic I have my Sound card in slot 1, gpu's are slot 2 and 5.
post-62868-0-68630400-1426770909_thumb.j
