Cheapest one I can think of is about $80 USD
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/329565-wireless-mic/#findComment-4473851
https://linustechtips.com/topic/329565-wireless-mic/#findComment-4473890
https://linustechtips.com/topic/329565-wireless-mic/#findComment-4473962
You aren't going to find anything good in ypour price range. More or less because you have to buy a couple other things to make it work right. Any reason a boring small desk mic wont work?
https://linustechtips.com/topic/329565-wireless-mic/#findComment-4474801
While recording from a phone? Or a camera?
probably a phone for a while, however, im thinking this http://www.amazon.com/Movo-PM10-Omnidirectional-Microphone-Smartphones/dp/B00N0EPZU8/ref=cm_cr_pr_product_topwould be a good option, since i have a 2nd person for camera, i could have audio sync with the camera and mic
https://linustechtips.com/topic/329565-wireless-mic/#findComment-4474859
Depending on your phone, all you are doing is convoluting what should be simple. Your phone is going to compress the audio no matter what you do, and unless its mic is really bad, you aren't going to see any improvements. Go for it if you want, but mind that the cable is a meter long and probably not going to be any better.
https://linustechtips.com/topic/329565-wireless-mic/#findComment-4474871
