Speaker wire help!
Go to solution Solved by bchampion96,
I recently got some new bookshelf speakers, but can't figure out which wire is red and which is black, one of the wires from the speaker has a silver sort of dotted line going down one side, and the other is solid black. (The speakers are Magnavox AH307M 3701s)
Black and silver is the 'red' one. The way I remembered it is that it's text sometimes instead of dotted lines. 'Red - (w)Riting'
https://linustechtips.com/topic/329399-speaker-wire-help/
Feel free to message me if you want to chat!
https://linustechtips.com/topic/329399-speaker-wire-help/#findComment-4471703
Black and silver is the red one.
Alright, thanks!
https://linustechtips.com/topic/329399-speaker-wire-help/#findComment-4471714
