RAM speed issue
Go to solution Solved by Ryouichi Kiriyami,
mark as solved :P
hello guys,
so ive been using my pc for about 3 months now and i was just going true my speccy list and noticed that my ram speed is very low
picture: http://imgur.com/opCicK3
so i did what i tought was right turn off my pc and go to the boot menu, in there i couldnt find anything relating to RAM speeds.
i use 2 sticks of hyperX fury black 4Gb 1600mhz,
the motherboard came with the case here are some of the specs: http://global.shuttle.com/news/productsSpec?productId=1581
please GHELP,
fassivemaggot
https://linustechtips.com/topic/328717-ram-speed-issue/
hello guys,
please GHELP,
fassivemaggot
Mash delete when turning on the PC, you will go into the BIOS, then set your ram modules to XMP
Please, follow your own posts and mention me in comments, otherwise i won't be able to help you.
Daily OS: OpenBSD -current
https://linustechtips.com/topic/328717-ram-speed-issue/#findComment-4461961
i did it and its still the same speed.
i was faced with choosing
[manual]
[custom]
[xmp profile 1]
[xmp profile 2]
there is no difference between custom and profile 1/2
https://linustechtips.com/topic/328717-ram-speed-issue/#findComment-4462025
[manual]
[custom]
[xmp profile 1]
[xmp profile 2]
What, does your motherboard support the speeds?
https://linustechtips.com/topic/328717-ram-speed-issue/#findComment-4462041
DDR3 1333/1600 MHz support RAM Socket * 4, Dual channels support
up to 32 GB total (8GB*4)
Did you put in the specific "clips" for the RAM?
https://linustechtips.com/topic/328717-ram-speed-issue/#findComment-4462066
what do you mean by clips?
Where you put the Ram in.
(btw, talking in dutch for a little: waar heb je die pc gekocht? Lijkt me wel vette build)
https://linustechtips.com/topic/328717-ram-speed-issue/#findComment-4462085
When you look at ram it only tells you the half speed of it.
"1 shot 1 kill. or in my case 500 shots and a questionable death" ~ Carlos Hathcock + Ryouichi
"Because its windows... it just happens..." ~ G33k 4 L1F3
My Build....sorta. close enough http://pcpartpicker.com/p/YMG4mG
https://linustechtips.com/topic/328717-ram-speed-issue/#findComment-4462096
well i put the dims in the board the right way making sure they were using dual channel.
and i build the pc myself,
bought the case+psu+motherboard as a bearbone on ibood.com (on sale)
bought the gpu from a friend for €70
and bought the rest new in local stores
https://linustechtips.com/topic/328717-ram-speed-issue/#findComment-4462117
i will try right now thx :D
SgtRafsta, Epic has no idea what he is saying. Ram speed on is usually shown in half so right now you are about at 1866mhz
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/328717-ram-speed-issue/#findComment-4462124
