So. Im tempted to build a new PC and I was wondering if I want to upgrade to a second graphics card. Im thinking of running a Gigabyte R9 280X and sometime in the future slamming in a R9 270X or another R9 280X. Pls help I will greately aprechiate it. Also is like 800W or 750W enough its probably not but... yeah.
https://linustechtips.com/topic/328192-how-much-power-do-i-need/
yeah its more than  enough for that
https://linustechtips.com/topic/328192-how-much-power-do-i-need/#findComment-4455690
Why would you put a 270X in there? You can't Crossfire the 280X with the 270X.
https://linustechtips.com/topic/328192-how-much-power-do-i-need/#findComment-4455701
For two higher end GPUs I'd use at least a 750 watt PSU. But I recommend a 800-850 watt PSU.
https://linustechtips.com/topic/328192-how-much-power-do-i-need/#findComment-4455726
Wait so 750w ps is enough for crossfire?
Yes.
https://linustechtips.com/topic/328192-how-much-power-do-i-need/#findComment-4455794
So is 750w overkill for this build
http://pcpartpicker.com/user/AncestralColt/saved/9QnMnQ
Yes, that build could run on a good 400-500w
https://linustechtips.com/topic/328192-how-much-power-do-i-need/#findComment-4457868
