I just got my network adapter a few days ago and so far im not at all impressed with it. It constantly seems that the connection drops out, because before i lost my other adapter it hardly ever seemed to drop out and it was a usb. I have a TP-LINK N900 wireless dual band PCI express adapter. I was wondering if this was a product that wasnt worth it and i should send it back and get something different or if i just got a janked one. If it isnt the best for the money i was wondering if you all could tell me one that is under the 50 price range. Thank you!
Motherboard:: Asus Maxiumus ROG Crosshair VII AM4     Ram:: G.SKILL TridentZ RGB Series 16GB (2 x 8GB)     SSD:: Intel 730 series 240Gb SSD
 GPU:: ASUS GTX 1080 8GB ROG Strix     CPU:: AMD Ryzen 7 2700x @3.70GHz   COOLING:: NZXT Kraken x72 AiO, 3x Thermaltake Riing Plus
https://linustechtips.com/topic/328094-help-with-my-network-adapter/
Have you installed the latest drivers? The adapter you got is a fairly decent model and should give you a decent performance if you're in range of the router.
CPU I7 - 4720HQ RAM 2 x 8GB • GPU Nvidia GTX 850M Storage 250GB 850 EVO - 1TB Seagate Hybrid
Keyboard CM Storm QuickFire Rapid-I (MX brown) & Pok3r (MX clear) • Mouse Logitech G502 • Sound Audio-Technica ATH-M50X • OS Windows 10 Pro - Linux Arch
Storage Asustor AS7004T
I installed them from the disk it came with
Go to their site. There's a good chance that the driver on the disk is an older version.
Nope its still doing it. It randomly drops to 1mbps
