does any of you use USB3.0 hubs?
my laptop only has one USB3.0 socket and i need to plug in 2 or more usb 3.0 external HDDs
http://www.amazon.com/Charging-Adapter-Included-VL812-B2-Chipset/dp/B00EYXZI4M/ref=cm_cr_pr_product_top
which is better, the 6+1 port or the 3 port + ethernet one?
looking at the reviews the 6+1 has more positive feedbacks
and will the transfer rate drop when multiple HDDs are transferring?
CPU: Intel Pentium G3258(OCed to 4.0 GHz at 1.25v)   Mobo: Asus Z87I-PRO  RAM: G.Skill Dual Channel DDR3-2133 8GB(2x4)  GPU: Sapphire Radeon R9-270 Dual-X OC version  Case: Bitfenix Prodigy M  OS: Kingston HyperX 3k 120GB  Storage/GameLib:WD Caviar Black 1TB  PSU: Corsair CX500  Monitor: Lenovo L193 Wide  Cooling: Corsair H100i AIO  Keyboard: Corsair Vengeance k70 Cherry MX Reds  Mouse: Corsair Vengeance M95  Speakers: Pioneer Home Theater 5.1 Surround  Headset: Kingston HyperX Cloud IIOS: Windows 7 Professional 64-Bit Laptop: Lenovo Z50-70 (Intel core I7 4510u; Nvidia geforce 840m; 1TB HDD, 8GB RAM; 15.6' 1920x1080)
https://linustechtips.com/topic/328017-usb-30-hubs/
Well if you don't need an ethernet port don't get the ethernet one...
https://linustechtips.com/topic/328017-usb-30-hubs/#findComment-4453760
I would buy based on how many devices you are going to plug in. The way you word it makes it sound like you may (at one point) Plug in more than 3 devices.
If your laptop already has an fully functional Ethernet port then a USB 3.0 one won't serve much purpose.
And yes, transfer rates will drop when multiple devices are transferring data over the port. The more devices trying to operate at once the slower things will be.
https://linustechtips.com/topic/328017-usb-30-hubs/#findComment-4455055
