Looks good
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
That build is so good. My only suggestion is maybe get 2*4 8gb ram, or If you can wait a few months you can get the new 300 series, just throwing it out there.
Basically each little bit of ram, so like one stick is one DIM....from what i know
I'll look into some 2x4gb options. Any recommendations that are a good price?
I would like to stay around $900 but if increasing my budget to around $1000 is better for a long term investment then $1000ish is my budget.
You could look into a better GPU, for 900-1000$ Look into the 970/ r9 290x
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
Here's a build just under $1000 with a 970, 2 sticks of ram and a cheaper motherboard.
Also the power supply you picked isn't available and wasn't adding up to the total cost of your build so I changed it.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($222.75 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($99.99 @ Newegg)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($329.00 @ NCIX US)
Case: Corsair 300R ATX Mid Tower Case  ($59.99 @ Micro Center)
Total: $982.66
Generated by PCPartPicker 2015-03-14 12:43 EDT-0400
Total: $982.66
I already own the power supply so that shouldn't be a problem. However, I was wondering if the power supply in my list was a good and reliable one.
Yes it is a very good power supply
Is there a relatively cheap motherboard similar to the one you suggested that as an optical audio port on it or should I just get a sound card?
I would have brought Krait Edition in a heartbeat if it had an optical port but instead went for this: http://pcpartpicker.com/part/msi-motherboard-z97gaming3
It's $23 more but has an optical port and an on board sound card but doesn't have SLI support.
I feel like not getting SLI support will hurt me in the long term, but I'm not completely sure. Do you think getting a separate sound card is a viable option?
Sound cards are usually expensive from what I remember
If you definitely need SLI and optical then this gigabyte board will work: http://pcpartpicker.com/part/gigabyte-motherboard-gaz97xgaming3
It's $125 and has everything you want.
