PC hangs at startup! HELP
Go to solution Solved by Bittenfleax,
Hello people, i need help, yesterday everything all day worked fine, today in the morning i turned on pc ant after couple moments pc starts ant launches it hangs :( , by the way yesterday then i turned off pc , windows got update and istalled it, today i checked parts , maybe my cpu socket some pin was broken, but no, all parts isn't broken, what should i do ?
Just wait, it might initializing updates.
If not do a Windows recovery.
https://linustechtips.com/topic/327304-pc-hangs-at-startup-help/
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/327304-pc-hangs-at-startup-help/#findComment-4445566
 @Tadziunia...
^ this...
...do what you can to check the software and see if it resolves it.
If it doesn't, then test the components. Take out one Ram stick, see if it makes a difference. If it works with that RAM stick then test the other RAM stick to see if that one works too, if they both work test them both together and if it fails again. If it does, use one of the sticks to test each slot (to see if a slot might be faulty) etc. etc.
Before testing the RAM, if you have a motherboard with a VGA port or other video port, and on-board graphics, remove the graphics card and run the monitor from the motherboard (to reduce the problem to as few components as possible).
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/327304-pc-hangs-at-startup-help/#findComment-4445585
 @Tadziunia...
^ this...
If it doesn't, then test the components. Take out one Ram stick, see if it makes a difference. If it works with that RAM stack then test the other RAM stick to see if that one works too, if they both work test them both together and if it fails again. If it does, use one of the sticks to test each slot (to see if a slot might be faulty) etc. etc.
okey ill do that
https://linustechtips.com/topic/327304-pc-hangs-at-startup-help/#findComment-4445646
