Will the G10 bracket be compatible to new products like the CM Nepton and Antec Kuhlers will fit, seeing that sockets haven't seen any major changes since G10's introduction.
If not, which brackets would these AIOs fit then?
The G10 will not be compatible with any Cooler Master branded AIOs.  The AIO you use with the G10 needs to be an Asetek branded AIO, and must have teeth around the edges of the pump.  Generally, the least expensive AIO to pair with the G10 is the H55, it works very well and is inexpensive.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
