Ok this is what I added/changed I want to make sure you guys think my case will fit and everything looks good and if their is anything i should add like fans cooling? maybe a bigger case and my budget is around 1200 to 1300 so I could add some its my first build so i want to be careful and I might overclock down the road but not really sure because i think i can run anything fine without over clocking with a 770
CPU Intel Core i5-4570 3.2GHz Quad-Core $188.98
Motherboard MSI Z77A-GD65 Gaming ATX LGA1155 $165.99
Memory G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1333 $69.99
Storage Western Digital Caviar Blue 1TB 3.5" 7200RPM $59.99
Video Card MSI GeForce GTX 770 2GB $399.99
Case Cooler Master HAF 922 (Black) ATX Mid Tower $79.99
Case Fan Cooler Master R4-S2S-124K-GP 44.7 CFM 120mm $7.99
Power Supply Corsair 750W ATX12V / EPS12V $79.99
Operating System Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Total: $1142.89
Steam:Drift and Drift_2 <p>(name is hunter) Lets play:)
https://linustechtips.com/topic/32714-build-advice-please/
I would change that CPU to get a i5-4670K and then change the motherboard to a Z87 because the Haswell CPUs are a 1150 Sockets not 1155 which are Ivy Bridge, also I would invest in better quality fans like silverstone AP122 or AP123, Corsair AF120 or SP120. Other than that solid build.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/32714-build-advice-please/#findComment-418254
how about this?
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($239.99 @ Newegg)
CPU Cooler:  Phanteks PH-TC12DX_BK 68.5 CFM  CPU Cooler  ($49.99 @ Newegg)
Motherboard:  Gigabyte GA-Z87-D3HP ATX  LGA1150 Motherboard  ($124.99 @ Newegg)
Memory:  Patriot Viper 3 8GB (2 x 4GB) DDR3-1600 Memory  ($59.99 @ NCIX US)
Storage:  Sandisk  128GB 2.5" Solid State Disk  ($84.99 @ NCIX US)
Video Card:  Asus GeForce GTX 770 2GB Video Card  ($399.99 @ NCIX US)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($89.98 @ Outlet PC)
Total: $1318.88
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-07-05 01:57 EDT-0400)
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/32714-build-advice-please/#findComment-418264
I heard windows is free :D
as far as everyone on this forum knows,you heard wrong.
because if for some reason you didn't hear wrong,and your suggesting that someone,somehow,obtain it through illegal measures it would be very bad.
2009630-lolcaption_funny_demotivational_
https://linustechtips.com/topic/32714-build-advice-please/#findComment-418297
I do already have win 7 on a other harddrive on my crappy HP could i transfer that over to the new rig and mvitkun thank you i will consider that
if u bought your laptop or desktop pre installed with windows 7, u cant transfer it. its not actualy a full copy of windows 7 that u would buy in a store in a stilly modified copy. this is what i have heard i have never tryed it though before.
https://linustechtips.com/topic/32714-build-advice-please/#findComment-418298
also i have never used an ssd what would I want to store on it?
the OS,any programs you intend to have start with windows,any programs you use often.
also as said above,you can not transfer an OEM copy of windows to a  different pc.
https://linustechtips.com/topic/32714-build-advice-please/#findComment-418301
oh srry for many questions should I get an optical drive cus how am I supposed to install windows 7 without it lol or can you download it? if so what type of drive (I dont care if its blue ray) without busting my bank and I cant find any reviews on that motherboard really Im considering it but any secondary options maybe that are little more popular?
https://linustechtips.com/topic/32714-build-advice-please/#findComment-418320
provided you have the  genuine code it'd be perfectly fine just to torrent windows 7 just to get the installation files,then you'd just put the files onto a usb.
or you could buy any random $15 optical drive.
https://linustechtips.com/topic/32714-build-advice-please/#findComment-418327
Haha, Okey
"I Heard Wrong" 8-) my mistake :s
https://linustechtips.com/topic/32714-build-advice-please/#findComment-418503
https://linustechtips.com/topic/32714-build-advice-please/#findComment-421898
