Wireless access points?
Solved by Oberon.Smite,
As long as you have a modem for each router, you should be good. Also, make sure your ISP has unlocked both of the lines.
Ryanwake ·
Posted in General Discussion1 -
1
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases1 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning17
play_circle_filled
Latest From ShortCircuit:
