depends what you deem affordable... the sweet spot cards are either a gtx 970 or r9 290x.
depends where you live. in the UK a 290x is much cheaper than a 970 and give equal performance. but in the US it's much more expensive than the 970.
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
What's your Budget? Location? What CPU you have?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
GTX 960 or r9 270,270x,280,280x,290,290x,295 from ASUS,EVGA,Sapphire, XFX, and many many more. Best one is the 280 or 280x from Sapphire.
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
Pretty much this.
Dubs are better than subs
I've looked into the 960 but haven't known if it was the right choice or not, I'll look into the 280 thanks for the help
If you have questions, you can PM me or put more questions on the thread. Also marked solved on the best thread answer.
Chase B
