Hey whats up folks.
So recently my 212 EVO broke... And now im running my rig on the stock Intel cooler. (specs in sig, I hope) And I would like to go AIO, since I can  :D
Now here's the point, what would be the best AIO cooler? I've been looking at the Corsair H100I, but I seriously have no idea what would be the best cooler. It also needs to look nice. I would like it to be atleast a 240mm rad since it just looks cool  :P. I also had a look at the new AIO from Corsair. The GT versions I believe. Are these any good? Are they actually on the market yet? As the shops here don't have them in stock.
I don't really have a budget. Just needs to be AIO as I'm to lazy to go custom and i don't have allot of time as I'm working and stuffs. It's currently not overclocked either. Already reaching avarage temparatures of around 40-ish.
I do like Corsair allot as i never had any trouble with them. So if you guys know what a good solution would be then do please let me know!
Ps. Its not like I dont know shit about pc's, it is just that I never had a pc running on liquid.  ;)
Thanks,
/K
Main rig / To swap the 970 for a ref card?!
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/
How did a heatsink break.............................................
Corsair Nepton 240m or for pure performance, NZXT Kraken x61
@ShockwavesXL
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4428911
Don't even ask!!  :P My mate and his kid were visiting.... And the kid was playing around whilst I was showing my mate my rig.... He kind off started throwing shit abouts....
Isnt the Nepton from Cooler Master? Also I hear allot of people had problems with the x61. Pump making weird noises and stuff...
Thanks though!!
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4428933
Thanks though!!
Yes the Nepton is from Cooler Master.
Never heard of problems with the x61.
@1Scotty1 You had any problems?
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4428961
With my X61? None so far :) runs like clockwork
Thanks @ShockwaveXL was having doubts about how it runs and that it may have problems and you are the only person I can think of at hand with an x61 :P
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4428975
Thanks though!!
My point is, it's made out of proper metal.. The fan might of broke or the mounting but I doubt the thing actually broke.
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4428982
Noisy pumps can be a pain, but I don't have that problem :) The noisiest thing in my pc are currently the intake fans spinning at 1900RPM :D I have to add some resistors to lower the RPMs, because they are on the H440 fan hub, which in itself is not regulated.
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4428990
Hah! yea it is.. It aint the heatsink that broke though, its the fan. I know I can just buy a new fan, But since I have the money and all, why not go liquid  :D
So the x61 is a good upgrade then? If so will order today  :P
You both have my thanks! Also for the fast replies lol.....
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4429042
Probably best temperature wise, expensive but pretty worth it in the long run :)
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4429075
I'm running a 4790k, you can find the rest in the link in sig I believe!
Then yeah, you can overclock like a boss with that CPU Cooler :)
https://linustechtips.com/topic/326094-upgrade-cpu-cooler/#findComment-4429253
