I got a used Pentium G3258 which worked before. I installed it into a Asus Z87-A motherboard. The Bios is up to date. When I turn the PC on, the CPU led just stays on. I already did a cmos reset and tryed another CPU, which worked. Anyone have an idea, if there is a way to safe the Pentium? I can't see anything wrong with it. I already called the Black Magic guy, he couldn't fix it either.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/325818-cpu-wouldnt-work/
Try re updating the BIOS maybe?
Reset everything and start again.
reset bios from inside bios and try again?
So you didn't go crazy on the overclock?
I did a cmos reset and I haven't OCed it. When I put the other CPU inside, the motherboard restarts 3 times and blinks, then it boots. With the Pentium it just turns the fan on and the CPU LED stays red.
https://linustechtips.com/topic/325818-cpu-wouldnt-work/#findComment-4425458
