Hi, this is my first... I'm on a strict budget. I've started playing Rift and as I got higher level with dungeons, rifts and all that my old computer is just lagging too much.
I currently have a
* Intel core II duo e7200
with a sapphire radeon hd6670
and 3 gb of ram...
im planning to get a
*Amd Phenom II x4 965 Black edition
*BIOSTAR TA970XE AM3+ AMD 970
*CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 1600
*then running 2 sapphire radeon hd6670 in crossfire
Will I see any bottlenecks and will I be able to run blops 2 and higher end games like that.
https://linustechtips.com/topic/32581-first-build/
What's your budget?
I'd recommend just paying a bit more for a stronger card. A 7850 would be much better.
You might be able to run black ops 2 at low-medium settings.
https://linustechtips.com/topic/32581-first-build/#findComment-416472
what is your budget?
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/32581-first-build/#findComment-416473
