I doubt any case has the space for a 3.5" AND a 2.5" in the same mount..
If it's an SSD, you could try just shoving it in there if there is space..
Don't take my word on it tho.
thank you I have asked this because in all the reviews I viewed Iv seen everybody say one or the other but when I looked at the case at the drive bays I see there is space for x2 on 1 bracket + u can see the screw holes from the bottom so the 3.5 on top with the tool less lock on the bracket and the 2.5 underneath it the question is did my eyes deceived me ?
Edited by Benielishackove
When i'm not playing PC games i'm playing with my PC parts  Fans,Pumps,Filters,  :wub:  :wub:  :wub:
thank you I have asked this because in all the reviews I viewed Iv seen everybody say one or the other but when I looked at the case at the drive bays I see there is space for x2 on 1 bracket + u can see the screw holes from the bottom so the 3.5 on top the bracket and the 2.5 underneath the question is did my eyes deceived me ?
Best way would be to ask someone who owns one to test it for you or to test it yourself..
I didn't open the box of the case yet still not building it (I did when I got it to incept any damage from shipping thanks to Linus's review then taped it up and its a sleep so "silence or I KILL you" achmed the dead terrorist quote (comedy)  don't mean any thing by it and don't mean to offend any body
no one with that case wants to talk with me because im a noob in the phantom bizz :) just got it 25 hours ago :wub:  :wub: :wub:  :wub:
@Benielishackove I just tried it. No, two of the screws hit the PCB of the hard drive, and that could possibly cause a short circuit.
Why don't you just install the SSD in a different hard drive rack?
"Rawr XD"
THANKS --->  x1 250gb 2.5" ssd + x2 5400 160gb 2.5" + x1 7200 200gb 3.5" + x2 7200 160gb 3.5" + x1 2tb 7200 3.5" = I need more places to put them or I can just let one go ill do a benchmark on them to see which is the slowest and maybe let him go to eternal sleep
Well keep in mind that SSDs can go anywhere, as they're solid state. They don't have to be mounted to anything.
"Rawr XD"
but if I wanted can I screw him in some way to the back of the mobo plate ?
Don't use Glue  :o otherwise you won't be able to remove it. Have a look for some double sided tape or velcro etc.
Like this - http://www.amazon.co.uk/Velcro-Heavy-Duty-Stick-Black-VEL60241/dp/B00186Q9AK
or this - http://www.amazon.co.uk/3M-9088-Double-Sided-Performance-Clear/dp/B00518NDBY
silicon glue or hot glue easy remove with some pressure and no marks after ty very much 4 the links
