a lot of coolers are useable on many different cpus, a h100 will fit on Intel LGA 775, 1155, 1156, 1366, and 2011 sockets, so will a 2011 water block fit on a 1150 socket? the block in question is a water cool water bock, it says its good for 2011 and 1366. i don't see why it wouldn't fit if the mounting holes line up, anyone have experience with this?
RIG:|Corsair Obsidion 650d|MSI Mpower Z87| i7-4770k (4Ghz)|Corsair H100 cooler|16Gb corsair dominator platinum 1866Mhz|  EVGA GTX 780 classified (runs at 1240Mhz)| 1200W pc power and cooling silencer mkIII PSU|recon sound blaster champion series| 1Tb WD black| 256Gb Samsung 840 pro| Monitors:| Samsung px2370| ASUS VG248QE| X-star 27" 2560x1440 korean monitor (runs at 100Hz)| other stuff:| Razer black widow ultimate| Razer mamba 2013 edition| Razer Vespula mousepad| Klipsch X10i| Ultrasone Pro750| Harmon/Kardon sound sticks 2|
https://linustechtips.com/topic/32517-water-block-compatibility/
if it fits, it sits. if it doesn't fit, it won't sit. just as simple is that, so it won't fit
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/32517-water-block-compatibility/#findComment-415706
The thing with cpu mounting hardware is it all has the same degree angle going out from the cpu the only thing that changes is the distance the hole is from the center of the cpu. Due to the different size socket type. Some blocks are specifit to that socket. Like a 1155 and 1156 have the same socket layout and i do beleive the 1150 has the same aswell. Have not looked into it. But the 1366 and 2011 are much larger chip sizes so if it isnt a universal mount it wont fit.
https://linustechtips.com/topic/32517-water-block-compatibility/#findComment-418152
