Hard Drive Failing?
Go to solution Solved by Altecice,
Nope there is nothing you can do, the drive might possibly be failing (if the sector count keep rising).
Hi,
I resently had a problem that my hard drive whould not open some files and sometimes the same files do open. I installed Crystal Disk Info and saw that the Current Pending Sector Count was at 1 - 1 - 0. On my other Western Digital drive it was 200 - 200 - 0. I don't know if this is bad. I Also noticed that the drive was used for more than 12000 hours. Probably the problem.
I backed up my files and stopped using the drive. Is there a program I can install to fix this problem because google is not helping me.
Thanks for helping,
Doggy
https://linustechtips.com/topic/324663-hard-drive-failing/
