A single 420mm rad is fine for cooling a cpu and a single gpu. You only needed the second rad if you were to cool a second gpu, as well.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/324503-do-i-need-two-radiators/#findComment-4408035
no, one is more than enough
https://linustechtips.com/topic/324503-do-i-need-two-radiators/#findComment-4408043
also before you watercool make sure that you will be happy with your computer for a while changing anything is a huge pain with watercooling
https://linustechtips.com/topic/324503-do-i-need-two-radiators/#findComment-4408046
So I am going to get a Phanteks Enthoo luxe an If I place a 240mm rad in the front will there be any places where I can but hard drives.
https://linustechtips.com/topic/324503-do-i-need-two-radiators/#findComment-4408081
You could buy a bracket that allows for HDD mounting in the 5.25" front bay. Otherwise, there is no other spot for HDD mounting. There are SSD brackets on the back of the motherboard tray, but an HDD wont fit.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/324503-do-i-need-two-radiators/#findComment-4411157
am using one of those, didnt know I had it until I went rooting through some boxes, its been a life saver for sure.
i5 4670k @4.2ghz / MSI Z87 G45 / EVGA GTX 960 SSC / Samsung  840 EVo SSD / WD Green 1tb HDD / Corsair H75 / Corsair Obsidian 750D / Corsair CS750M
https://linustechtips.com/topic/324503-do-i-need-two-radiators/#findComment-4413547
