HELP! Weird Files On Pc
Solved by Beltboy,
You've got show system files on, these are the recycle bin and the legacy docs and settings folder needed for windows xp software to run on windows 7+
They are perfectly normal every one has them, if you don'e like looking at them re-tick the Hide system files options.
You can't delete them cos they're aren't really there they are special system links that windows uses.
