Basically if you are wondering why it is loading thugs slowly the WD greens are I belive lower rpm so the are quieter but yet quiet
I dont mind the slow loading
i'm worried that the load/unload cycle has increase so much with 150 hours only
and in WD Website said that the WD only warranted < 300.000 load / unload cycle
