Yea that's totally fine on everything working together, pcpartpicker screams at you if there's issues. However, for a gaming rig, that is far, far, far more than you need, for an editing rig that's a good build. Either way, that's a beastly rig to have under your belt.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
Under Compatibility notes I can find this but I really dont understand
"Some Intel X79 chipset motherboards may need a BIOS update prior to using Ivy Bridge-E CPUs."
Just means that some older boards require a software update before they function correctly. However, if the board is being bought new, then it most likely already has the newer bios preinstalled, but if the board has been sitting in a warehouse for long enough then it might not have the newer bios. You should be fine though.
I am planning to build a gaming/editing PC for next month I want to know if this config is okay or if I am missing or have something extra here is the pc part picker link
http://pcpartpicker.com/p/YhhZP6
Thank You
For an editing job, dont you need the CUDA thing on Nvidia GPU more? And also dont those stuff need more SSD to reduce rendering time and stuff?
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
