So The audio is streamed, but I was curios if there was a way to make it cancel out with is coming out of the speakers? I like to listen to music while I game, and I co-op game, so being able to cancel that out would be awesome.
Secondly would be to either have live click removal, or a way to feed a program several audio examples and trains to automatically take it out?
https://linustechtips.com/topic/323250-live-audio-removing-noise/
what do you not want to hear?
Where is the mic?
and
You Could Try
in recording for the mixer enable
Noise Suppers ion
and Echo Cancellation
and then move mic closer to you
my mic is roughly 4 inches from my mouth, with a pop filter right on top of it. Cant really move it closer.
and
/\ above picture
try and see what happens
enable the effects and
also in
also in levels try lowering db boost a little maybe, (may need to talk louder then)
I don't have the "enhancements" tab...
THIS IS MY SUPER TEENY TINY SIGNATURE!
Ain't it just the cutest little signature.
Some would argue it is the cutest little signature ever.
is thier a device plugged into that port?
and drivers?
its a USB mic. I have it plugged into my PCIe adapter, but I have things in the other ports on the adapter that are working fine. checking drivers now...
post a screen of the recording tab? with all recording devices
