Build own PC
Solved by XTankSlayerX,
Hey man
All the "Cables" come with the power supply. The SATA Cables come with the mother board.
All the parts that need a driver will come with a CD with drivers on it. But it should still work, so you should get drivers from the internets.
As for checking parts, only parts I would be concerned about is if the mother board is the right socket for the CPU Your getting.
Also, checking if your motherboard is the right form factor for your case, other than that you don't have to choose a specific Graphics card or Hard drive to get
For wattage, you can make a basic system (1 Graphics card, CPU, HDD, etc) and only use up 500W
