I think their windows reserver drives
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
https://linustechtips.com/topic/322067-xps-13-partitions/#findComment-4377777
Take a screenshot of Disk Management.
I'm in the process of downgrading to Windows 8, so I can't really take a screenshot.
Partition 1: ESP - 500 MB, 470 MB - System
Partition 2: DIAGS - 40 MB, 35 MB - OEM (Reserved)
Partition 3: -128 MB, 128 MB - MSR (Reserved)
Partition 4: WINRETOOLS - 490 MB, 161 MB - Recovery
Partition 5: - 103 GB, 103 GB- Primary
Partition 6: PBR Image - 6 GB, 13 MB - Recovery
Partition 7: - 8.0 GB, 8.0 GB - OEM (Reserved)
https://linustechtips.com/topic/322067-xps-13-partitions/#findComment-4377779
Don't mess with them, those are boot and recovery partitions.
https://linustechtips.com/topic/322067-xps-13-partitions/#findComment-4377793
Okay.  One more thing, when I try to install Win 8 to the Primary drive, it says "Windows cannot be instaled to this disk.  The selected disk is of the GPT partition style."  What can I do to fix this?
https://linustechtips.com/topic/322067-xps-13-partitions/#findComment-4377803
As in, return to factory state?
Couldn't you just take that stuff onto a usb drive or something?
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/322067-xps-13-partitions/#findComment-4377804
If you want to re-install Windows 8, simply go under PC Settings > Update and Recovery > Recovery > Remove everything and reinstall Windows.
https://linustechtips.com/topic/322067-xps-13-partitions/#findComment-4378210
The problem is it won't let me boot into Windows because of that.  I just went ahead and installed Ubuntu, and am going to try to fix things from there.
https://linustechtips.com/topic/322067-xps-13-partitions/#findComment-4378228
Did you change anything the UEFI of the system? I have a feeling you enabled legacy mode (CSM), so Windows thinks that your system has the old BIOS system, and not the new modern UEFI recently introduced.
Did you system original came with Windows 7 or 8?
https://linustechtips.com/topic/322067-xps-13-partitions/#findComment-4378688
