Dark Rock Pro 3
Solved by Thorium19,
So you want to do some passive cooling? you'd better have some decent cooling in your case, because I wouldn't be doing this in a stock define R5 I'll say that now, not with overclocks. The shadow rock would work, but you'd need even better cooling than with the dark rock pro 3. Expect temps to be a fair bit higher than with the fans on.
PopsicleHustler ·
Posted in Audio0 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
