Hey guys
Recently overclocked my 4690k to 4.5Ghz with 1.28v but CPU-Z is displaying my vcore as 1.856v, it should be stating 1.28v shouldn't it?
Pic below of CPU Z screenshot.
Motherboard - ASUS GENE VII   CPU - i5-4690k   Ram - 2X4GB Corsair Vengeance Pro DDR3-2133MHz   GPU - ASUS GTX 970 STRIX 4GB   PSU - Corsair CX750   SSD - Samsung 840 EVO 250GB
Case - Bitfenix Prodigy M (White)   OS - Windows 8.1 (64x)
https://linustechtips.com/topic/321604-overclocking-voltage-help/
It seems like its reading wrong voltage because if your cpu would receive that much voltage, if would die instantly and if not that - it would make a lot of heat...
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
You can use other monitoring software to check the volts, frequency and temperature that its actively using.
If it really was getting 1.856V, it would be insanely hot and obvious thermal throttling will occur.
I was presuming it was a misread but was wondering if I was looking in the wrong place. What other monitoring software do you recommend for viewing the vcore?
