is there such a thing?
nope just the USB dongle
you might be able to make one (or just hide the usb dongle inside your case)
how  Alinware did it? was integrated in the motherboard?
Amd phenom ii x4 955 Asus crosshair iv formula Kingston hyperx fury 8GB 1600mhz ASUS Radeon R9 280X DirectCU II
Cooler master haf xb evo Antec 750w 500gb wd black BenQ gw2760hs Samsung 850 EVO 250GB 2.5" Solid State Drive
how did Alinware did it without it? was integrated in the motherboard?
it ships with a dongle
quote from their site
"WHAT CONTROLLER OPTIONS WILL WORK WITH THE ALIENWARE ALPHA?
We will ship the Alpha with a Wireless Xbox 360 controller and USB controller dongle. This dongle allows you to connect additional controllers."
I Second this getting it inside your case
how can I do it ? is there cable from usb header to usb port ? so I can put everything inside the case?
