I just bought the HyperX Cloud 2 headset to replace my broken Siberia V2's, and since the first moment I plugged it in, I can hear a faint white noise whenever there is a sound being made from the computer. Are there any solutions to this problem? *Note, I'm using the USB soundcard that came with the headset.
https://linustechtips.com/topic/320923-hyperx-cloud-2-headset-problem/
I had the same problem. I contacted HyperX and searched around myself a bit and it seems the USB soundcard they give you are just not the best quality.
You can try to send it back and see if a new one doesn't have this problem but I just bought a different pair of headphones.
EDIT: Just buy the HyperX Cloud 1, I had them in the past and they're great if you have a half-decent soundcard in your PC (newer motherboards have a great soundcard as well) it sounds awesome.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
Plug it into a different port? I'm unsure of the connectors on this headset, could be the port giving you noise. Does this happen with any other audio device?
I had the same problem and even plugging it in different PC's didn't fix it. The soundcard is quite low end to say the least.
If you got a usb hub (those thingy with lots of port), sometimes they can remedy noise problems. Depending on the quality and internal circuitry of the hub itself. It's not a sure shot though, so just try this if you got one lying around.
