Water cooling worth it?
Go to solution Solved by TheKDub,
Closed loop AIO's typically don't leak unless exposed to significantly cold temperatures, even then they may or may not leak.
and you can't really replace the liquid in them, and you don't really need to either.
This is my first system, so far I have been using the stock heatsink but I want to overclock and I've heard that water cooling is the best solution. I plan on getting the x61 kraken however I am cautious that it might leak... Is leaking common for closed loops and if it does leak how high are the odds it will ruin my system? Lastly how often will I have to replace the liquids for this specific cooler?
https://linustechtips.com/topic/320730-water-cooling-worth-it/
You dont change liquid in these type of coolers, when the pump stops working it is time to buy a new one ;)
I would personally get this one:
http://www.coolermaster.com/cooling/cpu-liquid-cooler/nepton-240m/
Asetek solutions can be a bitch to mount sometimes, my experience.
https://linustechtips.com/topic/320730-water-cooling-worth-it/#findComment-4359356
https://linustechtips.com/topic/320730-water-cooling-worth-it/#findComment-4359362
Unless you damage it, it will never leak
https://linustechtips.com/topic/320730-water-cooling-worth-it/#findComment-4359410
Performance to price then technically no, its more of an enthusiast kind of thing for people with shit tons of cash :P, ONly upside i really see from it is slightly better temps and its quieter :)
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
https://linustechtips.com/topic/320730-water-cooling-worth-it/#findComment-4364420
Generally not worth it compared to high-end air coolers.
All-in-one water cooling is more expensive and generally noisier than air coolers with comparable performance. Water cooling only really separates itself at the high end, where you just can't get a bigger air cooler.
https://linustechtips.com/topic/320730-water-cooling-worth-it/#findComment-4364935
