https://linustechtips.com/topic/320685-enermax-vs-cooler-master/
uhhh go with EVGA...600W much better and cheaper
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($54.99 @ Amazon)
Total: $54.99
Generated by PCPartPicker 2015-03-02 18:51 EST-0500
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/320685-enermax-vs-cooler-master/#findComment-4358770
I would go for the Cooler Master V650 if you don't want to deal with rebates. It also offer better internal components, DC quality output, and better native connectivity.
Total: $54.99
Both the Cooler Master V650 and the Enermax Revolution X't 630w is better than the entry level EVGA 600B in respect to electrical performance (DC-DC vs group-regulation), efficiency (Gold vs Bronze), functionality (semi-modularity), and warranty (5 year vs 3 years). The V650 also provide the native connectivity for SLI / CFX (four PEG connectors vs two), while the X't has three PEG connectors.
https://linustechtips.com/topic/320685-enermax-vs-cooler-master/#findComment-4358896
Thanks. So is the V650 worth the extra $20?
Well, rebates isn't always a guarantee and without it, it's pretty much a bad deal for being over $90. Since you can get it $15 cheaper initially, the V650 is more worth it in my eyes, as I don't have to deal with the rebates and it offer better build quality and performance.
I find the EVGA Supernova 750w B2 more attractive than the Enermax Revolution X't. http://pcpartpicker.com/part/evga-power-supply-110b20750vr
Even though it is a Bronze rated unit, it can do silver efficiency. It's also offer better internal components and better DC quality output. Since it is already a great deal for $79.99, I don't mind buying this over the V650 and take the chance with the rebate (if you do get it, you just got the best value PSU in the $60 price point).
https://linustechtips.com/topic/320685-enermax-vs-cooler-master/#findComment-4359197
