So i'm wanting to do a build that will run games like Crusader Kings 2, EU4, Civ 5, things of that nature at 1080p and an easy 60fps at max settings. What would y'all recommend my build consist of. I have a budget of around $400 - $600. The cheaper the better. All help is appreciated. Thank you!
EDIT: sorry i didn't mention this before but i would like the os included in the price as well. thank you!
https://linustechtips.com/topic/320639-first-build-please-help/
Alright, give me a sec and I'll see what I can do!
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/320639-first-build-please-help/#findComment-4358166
PCPartPicker part list: http://pcpartpicker.com/p/ZqKcP6
Price breakdown by merchant: http://pcpartpicker.com/p/ZqKcP6/by_merchant/
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($78.78 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.98 @ OutletPC)
Motherboard: ASRock FM2A88X PRO3+ ATX FM2+ Motherboard  ($72.55 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-2133 Memory  ($54.99 @ Newegg)
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Drive  ($58.84 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card  ($159.99 @ Newegg)
Case: BitFenix Neos Black ATX Mid Tower Case  ($34.99 @ NCIX US)
Power Supply: Enermax REVOLUTION X't 530W 80+ Gold Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Total: $589.10
Generated by PCPartPicker 2015-03-02 17:40 EST-0500
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/320639-first-build-please-help/#findComment-4358261
not that bad imo, add ssd later on (its not really a necessity) and mobo is Z97 so cpu upgrade down the line will be easy :D
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.99 @ NCIX US)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($79.99 @ Micro Center)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($62.99 @ Newegg)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($218.98 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($48.00 @ NZXT)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Micro Center)
Total: $613.91
Generated by PCPartPicker 2015-03-02 17:50 EST-0500
https://linustechtips.com/topic/320639-first-build-please-help/#findComment-4358341
PCPartPicker part list: http://pcpartpicker.com/p/3v3mK8
Price breakdown by merchant: http://pcpartpicker.com/p/3v3mK8/by_merchant/
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($119.99 @ Amazon)
Motherboard: Asus A88XM-A Micro ATX FM2+ Motherboard  ($64.99 @ NCIX US)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2400 Memory  ($73.97 @ OutletPC)
Storage: Crucial V4 32GB 2.5" Solid State Drive  ($35.95 @ Amazon)
Storage: Western Digital AV-GP 500GB 3.5" 5400RPM Internal Hard Drive  ($33.50 @ Amazon)
Video Card: Sapphire Radeon R7 250 1GB Video Card  ($72.99 @ SuperBiiz)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($24.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.75 @ OutletPC)
Total: $564.10
Generated by PCPartPicker 2015-03-02 19:36 EST-0500
597$ before rebates. Includes os. Ssd just for os, thats why it's 32 gb. 500 gb hard drive cause can always just buy external drive or add another later and cheaper, 500 gbs should be good to start. Amd apu with high clocked ram will boost its performance alot. Can dual graphics with the r7 250 put in the build so another performance bump.
https://linustechtips.com/topic/320639-first-build-please-help/#findComment-4359049
