I am doing a school assignment using Kinect (Xbox 360) in Unity.
Everything is downloaded and installed, including a sample project. It all works and the body in the sample works fine.
That all works.
But the thing that doesn't work are the colliders.
The body is a different gameobject from the colliders (which I need in what I am making)
I have tried everything it feels like, but it just doesn't work :(
Do you guys have any suggestions or other sample projects I can use?
https://linustechtips.com/topic/320303-kinect-unity3d-help/
so all the colliders from other gameobjects don't work?but the rigidbody works?
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/320303-kinect-unity3d-help/#findComment-4353679
The colliders don't seem to be aligned properly with the skeleton used.
When 2 colliders collide, nothing happens (I have a debug.log and some kind of event going on when 2 things collide)
I don't have rigidbodies, do I need that?
This is a small snip from the collision code:
void OnCollisionEnter (Collider other)	{		//Debug.Log("Enter");		if (other.name == "/AllCubes/CubeMiddle") 		{			BlokkenBewegen.MoveCube2();			print("touches "+transform.position.x);			lives--;		}         }
https://linustechtips.com/topic/320303-kinect-unity3d-help/#findComment-4353768
In unity, in order for a collision to happen at least one of the GameObjects needs a rigidbody.http://docs.unity3d.com/ScriptReference/Rigidbody.OnCollisionEnter.html
The reason for this is, that for a collision to happen, it needs to a collision response, but unity is not allowed to move a GameObject if it doesn't have a RigidBody. If you want to check if they are colliding without having a collision response happening, you should mark you colliders as triggers.
I hope this solves you problem.
https://linustechtips.com/topic/320303-kinect-unity3d-help/#findComment-4354368
here you go :)
https://linustechtips.com/topic/320303-kinect-unity3d-help/#findComment-4358460
