Reading this in the post:
[JSMorley: Link removed. This plugin is very old, and unsupported by the original author. It should not be used.]
Just saying....
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
Hi,
I want to install this plugin http://rainmeter.net/forum/viewtopic.php?f=18&t=6874,but I don't know how to.
What exactly does this plugin do? Im sure theres an good alternative with an installer.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
I have used Rainmeter quite extensively and I can tell you that you don't want to use Rainmeter to poll things like temps/utilization. Its method of doing so is very basic and will put quite a strain on your CPU at all times. Live without it. An alternative would be to use a program like AIDA64 that has the ability to put tray icons on your start bar for anything in your system that has a sensor.
Quack 🦆
