LearnPythonTheHardWay ex25 Help
Go to solution Solved by SIGSEGV,
def sort_words(words):
"""Sorts the words."""
return sorted(words)
By calling that little snippet there
Here is the link to exercise 25: http://learnpythonthehardway.org/book/ex25.html
So I followed the entire thing, typed in all the code and ran it like I was supposed to. No problem there.
I just don't understand how he alphabetized the words. I probably should mention this is my first language I am learning.
I can't see how that happened in the code.
If someone could explain how he did that that would be awesome.
https://linustechtips.com/topic/318009-learnpythonthehardway-ex25-help/
def sort_words(words):    """Sorts the words."""    return sorted(words)
https://wiki.python.org/moin/HowTo/Sorting
def sort_words(words):    """Sorts the words."""    return sorted(words)"
That returns the items in sorted order
Lol... I thought it was a lot more complicated thanks! :D
