Hey all I'm buying and building my first PC tomorrow :D
I posted this before but forgot to add one major reason everything is expensive....I live in AUSTRALIA and shipping from America is HORRIBLE.
Here are the specs:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($249.00 @ CPL Online)
Motherboard: Asus H97I-PLUS Mini ITX LGA1150 Motherboard  ($135.00 @ CPL Online)
Memory: G.Skill Value 8GB (1 x 8GB) DDR3-1600 Memory  ($89.00 @ CPL Online)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($72.00 @ Centre Com)
Case: Silverstone RVZ01B Mini ITX Desktop Case  ($97.00 @ CPL Online)
Power Supply: Silverstone 450W 80+ Bronze Certified SFX Power Supply  ($99.00 @ CPL Online)
Wireless Network Adapter: TP-Link TL-WN725N 802.11b/g/n USB 2.0 Wi-Fi Adapter  ($9.90 @ CPL Online)
Case Fan: Thermaltake CL-F011-PL12BL-A 41.0 CFM 120mm  Fan  ($11.00 @ CPL Online)
Other: Sapphire R7 260X (Purchased For $110.00)
Other: Windows 8.1 PRO (Purchased For $30.00)
Other: Samsung Evo 120GB (Purchased For $100.00)
Other: Toshiba Bluetooth USB 2.0 ($30.00)
Other: 10 Port USB 2.0 Hub ($20.00)
Other: Additional Cables ($10.00)
Total: $1061.90
Im just running it by here to ask if you think that i might run into any problems like incompatibility, issues ect.
I can not wait to build this thing i have been waiting a year :D
Thankyou peeps :)
https://linustechtips.com/topic/317779-custom-build-help/
It looks good to me, but you should run your build through http://www.pcpartpicker.com/It makes it easier to share builds, it will find you the best price for each piece of hardware, and will even report incompatibility issues to you!
https://linustechtips.com/topic/317779-custom-build-help/#findComment-4319209
Here are the specs:
Total: $1061.90
Thankyou peeps :)
Budget?
https://linustechtips.com/topic/317779-custom-build-help/#findComment-4319232
I dont know if you chose CPL for a reason or not...but your identical build would run MUCH cheaper if you used other vendors. You could also get some decent upgrades if you wanted to use that budget anyways - For instance: you could get a 4690k for $15 less, an ASUS Z97 board same price, etc etc
PCPartPicker part list: http://pcpartpicker.com/p/2wWXpg
Price breakdown by merchant: http://pcpartpicker.com/p/2wWXpg/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($178.99 @ NCIX US)
Motherboard: Asus H97I-PLUS Mini ITX LGA1150 Motherboard  ($100.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory  ($62.98 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($51.89 @ OutletPC)
Case: Silverstone RVZ01B Mini ITX Desktop Case  ($83.99 @ SuperBiiz)
Power Supply: Silverstone Strider Gold 450W 80+ Gold Certified Fully-Modular SFX Power Supply  ($89.99 @ SuperBiiz)
Wireless Network Adapter: TP-Link TL-WN725N 802.11b/g/n USB 2.0 Wi-Fi Adapter  ($9.22 @ OutletPC)
Case Fan: Thermaltake CL-F011-PL12BL-A 41.0 CFM 120mm  Fan  ($11.04 @ Newegg)
Other: Sapphire 260x (Purchased For $110.00)
Other: Windows 8.1 (Purchased For $30.00)
Other: 10 Port USB Hub ($20.00)
Other: Toshiba Bluetooth USB ($30.00)
Total: $889.09
Generated by PCPartPicker 2015-02-26 05:41 EST-0500
Another option if vendor doesn't matter, at your original price range(well still lower, but you already purchased a graphics card):
PCPartPicker part list: http://pcpartpicker.com/p/zYkT3C
Price breakdown by merchant: http://pcpartpicker.com/p/zYkT3C/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.75 @ OutletPC)  <--------
CPU Cooler: Silverstone AR05 40.2 CFM CPU Cooler  ($39.99 @ Amazon)   <--------
Motherboard: Asus Z97I-PLUS Mini ITX LGA1150 Motherboard  ($148.99 @ SuperBiiz)    <--------
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($129.98 @ OutletPC)    <--------
Total: $1084.84
Generated by PCPartPicker 2015-02-26 05:55 EST-0500
https://linustechtips.com/topic/317779-custom-build-help/#findComment-4319235
Here are the specs:
Total: $1061.90
Thankyou peeps :)
It's up to you of course, but we can get you much better specs for the money if you wish. $1000 is more than enough to make something that far outstrips that.
https://linustechtips.com/topic/317779-custom-build-help/#findComment-4319259
2x4GB RAM if possible for dual channel.
Otherwise, great build!
More expensive than it should be..
https://linustechtips.com/topic/317779-custom-build-help/#findComment-4319298
....i copied it from my pc part picker haha :P
https://linustechtips.com/topic/317779-custom-build-help/#findComment-4319473
Looks good, The Sapphire 260x might have a hard time to keep cool since it isnt a blower style cooler, But i dont think it would be too bad since it has a relatively low TDP.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/317779-custom-build-help/#findComment-4319625
