you cannot have more that 4 gpus in a system and 1500w will power any 4 way system so 2 psu s is stupid nowadaya anyway 7 gpus woudnt fit on that motherboard uinless they are quadros anyway the point is : MAXIMUM 4 Way SLI/ Crossfire
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/317439-dual-psu-systems/#findComment-4314297
Are Dual-PSU in one system still problematic or do they work flawless nowadays?
Would it be possible to have 7 GPUs with ASUS Z10PE-D8 WS, each GPU running at 8X?  (need a WS for rendering).
Should be fine. Cases such as the Corsair 900D, Cooler Master HAF 932, and Cooler Master Cosmos II are all great cases that will take dual PSU's.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/317439-dual-psu-systems/#findComment-4314300
You can have way more than 4. 4 is the max for gaming software like SLI and Xfire but professional machines can take as many as they can fit.
https://linustechtips.com/topic/317439-dual-psu-systems/#findComment-4314307
ahh ok thought he was gaming but 7 woudnt fit on that board anyway uinless hes getting quadros or skint GT 210 cards or somthing
1
https://linustechtips.com/topic/317439-dual-psu-systems/#findComment-4314310
Without SLI there is no point in multi gpu
1
https://linustechtips.com/topic/317439-dual-psu-systems/#findComment-4314315
SLI is gaming only. Editing suites can take use of multiple cars but they comm via PCI lanes and not SLI cables.
https://linustechtips.com/topic/317439-dual-psu-systems/#findComment-4314326
ahh ok i dont do any edditing so yea however 4 will do any modern rendering/ editing
1
https://linustechtips.com/topic/317439-dual-psu-systems/#findComment-4314334
Well.... he could use if for Folding or BOINC. Those have 100% scaling, even with 7gpus.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/317439-dual-psu-systems/#findComment-4314654
