So I'm using a lamptrob fan controller ATM and it's busted. Some of the time it doesn't even work so anyone kmow of any good fan controllers out there?
You're in luck! You have an ROG board and because of that, you can get this: Motherboards - ROG Front Base - ASUS
I've has two of them and my god are they amazing.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/317302-fan-controller/#findComment-4312372
I thought those were the good ones :(
It worked fine but after 4 months its busted 2 out of the 6 controllers (I have the 6 fan model) don't work. Doesn't give the fans power unless I make it 12v - 0v over and over.
Either you're master race or you're not.
https://linustechtips.com/topic/317302-fan-controller/#findComment-4312377
I really just need to control my fans. How's the price of the front base? On my phone ATM so can't check. Thanks.
https://linustechtips.com/topic/317302-fan-controller/#findComment-4312390
When they're in sotck they're like $80, but they monitor all of the stats, from CPU clocks to temps, etc. Aside from this, I dont have any rec's.
https://linustechtips.com/topic/317302-fan-controller/#findComment-4312406
That's about the same as the lamptron one I brought. How many fans do they control?
https://linustechtips.com/topic/317302-fan-controller/#findComment-4312435
that just tells me how to control speeds, I need a fan controller.
https://linustechtips.com/topic/317302-fan-controller/#findComment-4315453
