help quickly!
My friend is getting new gpu today
Specs: i5 4690k, asus mb with only crossfire supp.
8gb ram. Cx600 psu
should he go for r9 290(x?) or gtx 970
Hes using my old gtx 660 and wants to upgrade bc gta v and bf4
I'd get the 970, but otherwise get a 290X.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/317076-help-quickly/#findComment-4309522
GTX 970 should do the trick, plus it has 3 displayports for better multi display options.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/317076-help-quickly/#findComment-4309527
both trade blows
the 290X is way cheaper thou
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/317076-help-quickly/#findComment-4309546
970 because quiet
GTX 970.
8gb ram. Cx600 psu
290x because proper 4gb's of vram and better bang for your buck.
Noise and heat is barely an issue these days.
https://linustechtips.com/topic/317076-help-quickly/#findComment-4309762
both trade blows
http://m.newegg.com/Product/index?itemnumber=14-121-899
http://m.newegg.com/Product/index?itemnumber=14-131-548
Decent 970 vs cheapest 290x. You can get a cheaper 970 but I wouldn't recommend those. Just showing that the prices are pretty close.
Go with the 970 OP
https://linustechtips.com/topic/317076-help-quickly/#findComment-4310696
If it's just 1080p gaming, which it looks like to me when I look at the specs of this machine, I'd say go with a GTX970 and call it a day.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/317076-help-quickly/#findComment-4311759
8gb ram. Cx600 psu
Everybody is advising gpus like that, what resolution will your friend be playing?
https://linustechtips.com/topic/317076-help-quickly/#findComment-4311966
