Don't get the 5930K even if you like the pride of having a "Because-You-Can" Item it's not worth it. Also if you are going to weave you video (or whatever) internally get a second and run it in raid 1
Get a second what? Also I don't have the money at this exact moment but I can wait to get enough money for each part.
https://linustechtips.com/topic/316941-workstation-build-check/#findComment-4307970
Only get 16GB of RAM unless you are hardcore about rendering and editing.
https://linustechtips.com/topic/316941-workstation-build-check/#findComment-4308000
PCPartPicker part list: http://pcpartpicker.com/p/6LVdzy
Price breakdown by merchant: http://pcpartpicker.com/p/6LVdzy/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($322.99 @ SuperBiiz)
Motherboard: Asus Z97-PRO ATX LGA1150 Motherboard  ($179.98 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory  ($127.98 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.99 @ Adorama)
Storage: Western Digital BLACK SERIES 4TB 3.5" 7200RPM Internal Hard Drive  ($198.99 @ NCIX US)
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card  ($544.99 @ SuperBiiz)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($149.99 @ Amazon)
Power Supply: SeaSonic Platinum 860W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($160.98 @ Newegg)
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD Writer  ($39.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($101.98 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($36.79 @ OutletPC)
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm  Fan  ($18.98 @ OutletPC)
Case Fan: Noctua NF-A14 PWM 82.5 CFM 140mm  Fan  ($26.30 @ Amazon)
Monitor: Asus PB278Q 27.0" Monitor  ($0.00)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($112.99 @ Newegg)
Mouse: Logitech G502 Wired Optical Mouse  (Purchased For $0.00)
Other: EK-Supremacy EVO - Acetal ($71.59)
Other: EK-FC980 GTX Strix - Acetal+Nickel ($130.72)
Other: D5 Photon 170 Glass 410ML Reservoir / Pump Combo ($150.08)
Other: EK-CoolStream PE 240 (Dual) ($57.38)
Other: EK-FC980 GTX Strix Backplate - Black ($33.84)
Other: TUBE PrimoChill PrimoFlex™ Advanced LRT™ 12,7 / 9,5mm - Crystal Clear RETAIL 3m ($22.91)
Other: Americolor 133ml Liquid Gel Food Color, 4.5-Ounce, Super Red ($10.00)
Other: Rosewill RTK-002 Anti-Static Wrist Strap Components Black, Yellow ($6.99)
Other: EK-ACF Fitting 10/13mm - Nickel (8) ($40.56)
Other: EK-CoolStream RAD XTC (420) ($107.91)
Total: $2936.46
Generated by PCPartPicker 2015-02-24 21:15 EST-0500
Overclock the cpu, wait for Windows 10, and possibly rethink all of the Noctua.
sold
https://linustechtips.com/topic/316941-workstation-build-check/#findComment-4308038
When I look at your avatar I read your reply in caps.......lol
I did for a sec too.
https://linustechtips.com/topic/316941-workstation-build-check/#findComment-4308051
Total: $2936.46
What is wrong with Noctua?
https://linustechtips.com/topic/316941-workstation-build-check/#findComment-4308062
This build will be mostly for video creation a gaming here and there. In my mind I say there is a price limit but in reality there is not. http://pcpartpicker.com/p/dYybxr
An i7-5820K will provide very similar performance to the i7-5930K in this build.
The psu is oversized. An 850 would be more than enough. I would suggest the EVGA 220-G2-0850-XR which is the best value in its class - (excellent quality, very good price).
https://linustechtips.com/topic/316941-workstation-build-check/#findComment-4308119
