so i just built a tiny pc for my uncle, i had a gpu laying around and plugged it in. im using a TV as a monitor but the gpu didnt display anything out, there is not OS installed or anything. i cant see the normal mobo startup screen or anything, the tv says that it has no video signal. so i took the gpu out and since im running a AMD A10, i plugged the HDMI cable into the mobo itself and tried it again, but its the same problem. how can i fix this, its not like the mobo is dead or anything all the fans and cpu cooler all work.
here are my specific parts...
http://www.amazon.com/AMD-A10-5800K-3-8Ghz-Processor-AD580KWOHJBOX/dp/B0095VP8D4/ref=sr_1_2?ie=UTF8&qid=1423967966&sr=8-2&keywords=amd+A10k
http://www.amazon.com/MSI-Computer-Corp-Motherboard-FM2-A75IA-E53/dp/B00A2VJIQE/ref=sr_1_1?ie=UTF8&qid=1423968440&sr=8-1&keywords=amd+fm2+itx
Space Journal #1: So Apparently i  was dropped on the moon like i'm a mars rover, in a matter of hours i have found the transformers on the dark side of the moon. Turns out its not that dark since dem robots are filled with lights, i waved hi to the Russians on the space station, turns out all those stories about space finding humans instead of the other way around is true(soviet Russia joke). They threw me some Heineken beer and I've been sitting staring at the people of this forum and earth since.
https://linustechtips.com/topic/316307-urgent-pc-help/
Sounds like you need drivers for the HDMI but I could be wrong.
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4298950
Getting and POST Codes by chance?
theres no post lcd on the mobo, the TV doesnt take DVI so i gotta go dig around for a VGA cable.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4298964
Negative for visual ones; I am talking about traditional 1 Beep good, then the rest the manual says what they indicate.  Do you even get a single beep on startup?
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4298970
i guess so, usually a mobo detects it right away and changes it accordingly, ive never installed a hdmi driver, i guess i gotta go look for a VGA cable becauses TV's are butt.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4298971
i plugged in the speaker and it didnt work.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4298984
I had an issue that manifested itself like this, ended up being the mobo bios was out of date.
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299017
Can you try it with a different cable? (i.e. not HDMI but something more standard?)
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299063
So you hear nothing when you boot; or did you test the speaker on another machine or?
my asus board didnt come with a speaker or the cases that i bought, i did plug in the speaker both ways into the baord and it didnt beep, so i thought that its not that important and just left it out.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299073
Right; consult the manual to get the correct polarity; that is critical for beep codes or the post beep at startup to diagnose this machine.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299083
Usually when you don't have drivers installed or anything, you want to plug the display in via VGA (which is what it is probably outputting a signal to).  That worked with my Asus Maximus VII Hero.
Main Rig:
i7 4790k @ 4.4GHz w/ H75 Liquid CPU Cooler - Asus Maximus VII Hero - 16GB G.Skill Triedent X 2133MHz RAM - 2x Gtx 660s in SLI - 120GB Crucial SSD - 1TB WD HDD NZXT Hue - K70 RGB Keyboard - Corsair Sabre RGB - Windows 8.1 - 2x Asus VN247H-P 1080p Monitors (I'm a sucker for lighting effects)
Server:
FX 8350 @ 4.0GHz w/ stock cooler - 8GB Crucial 1600MHz RAM - AMD Radeon HD 7450 GPU - 300W PSU - 120GB SSD - Windows 7
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299107
@Tocsin_786 Beep codes can be really helpful. If you can get the speaker working it might help?
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299108
i cant find a vga cable, im gonna put the gpu back in and see if i can use my dvi monitor to see if it works.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299138
It doesn't have a DVI plug on the back of the computer on the motherboard?
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299155
no, only hdmi and vga.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299183
It also doesn't POST code if the BIOS is out of date.
There are only two wires to a speaker.  The SPEAKER, and COMMON.  A speaker with one wire going to each of those will work.
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299186
Okay. It's just easier to reduce the problem down to the most basic components but if you need the GPU installed for the cable I guess that's just how it's got to be.
It's not impossible to get it working without the beep codes it just makes it easier to figure out what the problem is and whether it can be solved.
Try it with the GPU and the DVI cable?
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299210
i opened up the case and the cpu fan just kept stopping. i thought some wires were obstructing it, so i cleared the wires out and now my system just wont start. im gonna take everything out and route the wires correctly, i dont think the cpu burnt out because the case is so small that i have a 80mm fan thats just shoving air right into the heatsinks
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299242
Also, if it's a newer CPU hopefully it would have throttled itself and booting isn't very demanding. I've had times when my pump cable's got unplugged when I've just been looking at forums and it's been okay. Hopefully it should be okay.
Thing is it's late where I am and I have to get some sleep so I'm going to have to log off. :0/
But good luck with it. I should be on the forum again tomorrow so if it's still giving you problems I might be able to help then?
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299286
okay i got it working, turns out my old amd card is dead but i had an nVidia 210 laying around and is working, as for the cpu i had the damn power switch off :P
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299380
What did we learn.. always ask the stupidest question 1st.. is it turned on? HAHA
this was probably the worst build experiance, linus was right. the Cooler Master Elite 110 is a tough case to build in, when i went to present to my uncle that im finally done building in it, he thought i bought him a heater cuz it looked like one :P
https://linustechtips.com/topic/316307-urgent-pc-help/#findComment-4299888
