I began my original Primo Midas build last year and wanted to share with you guys as a new member to these forums, my original log was on OcUK.
Here http://forums.overclockers.co.uk/showthread.php?t=18560177
I'm in the process of upgrading from an Asus X79 Deluxe running an Intel 4930k.
My "Evolution" of "Primo Midas" will involve changing to an Asus Z10PE-D8-WS using Intel Xeon V3 2.2Ghz 14 core CPU's which are engineering samples.
GZwDoDt.jpg?1
https://linustechtips.com/topic/314812-project-midas-evolution/
better than black and white builds
edit: will save some pics for later
edit 2: what are you doing that you need a 14-core cpu?
"Primo Midas" was always built with Folding@Home and BONIC in mind, I crunch for OcUK. Also I thought it would look "beast" once I watercool it again !
More money than sense  ;)
There are are a lot more images on my original log, I didn't want to post too much here.
https://linustechtips.com/topic/314812-project-midas-evolution/#findComment-4279506
Damn man , I wish I'll have a job that will make such builds possible...
Longboarders/ skaters message me!
https://linustechtips.com/topic/314812-project-midas-evolution/#findComment-4279532
This was how my build looked this morning before I begun the upgrade
Now some work after having tested my new parts.
When I saw this picture is was like HOLLY COWS. So jealous right now ;o
https://linustechtips.com/topic/314812-project-midas-evolution/#findComment-4281131
I work in the offshore industry and am away from home a lot, so this is how I spend my free time and my money. I did try to get some sponsors onboard but I guess I don't have much exposure yet plus I really need to improve my photo skills.
https://linustechtips.com/topic/314812-project-midas-evolution/#findComment-4284300
@colinmcr Why are WC Xeon's
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/314812-project-midas-evolution/#findComment-4308084
  • 6 months later...
Long time but I've been so busy with house renovation and working abroad just never have much time, I've got to the point of bending hardline but I was finding it rather frustrating and ended up working on a different build. I've promised my folding buds that'll have it working soon... Not much to show and tbh I'm maybe gonna finish it in soft tube just to get it back folding again,its been sat idle for too long. Maybe when I get time to practise more harline bending I'll finish it properly.
https://linustechtips.com/topic/314812-project-midas-evolution/#findComment-6015225
  • 4 weeks later...
To get the build finished and working again and after some of my hardline fittings cracking and leaking !! I went back to soft tubing except for the line from res into cpu1 inlet. System is running and busy working on compute projects for BONIC and Folding@Home.
I didn't want to run the risk of the collars failing again considering the cost of the hardware.
Full images are here ----->>>>http://imgur.com/a/0bURH
https://linustechtips.com/topic/314812-project-midas-evolution/#findComment-6213074
