Any advice on my airflow planning?
CPU: AMD A10-6800K Cooler: Deepcool Gamer Storm Captain 120 GPU: Radeon R9 270X Cooler: Sapphire Dual-X Air-Cooler Mobo: Gigabyte F2A88X-D3H RAM: 1600MHz Samsung 8GB (4GB x2) SSD: ADATA SP900 128GB Storage: Seagate SSHD 1TB Case: Corsair Graphite 230T
Planned Upgrades: Some better RAM kit, NXZT H440 Black Windowed (I RLY WANT DIS), Dream-PC PCPartPicker URL: http://pcpartpicker.com/p/jMTHK8
https://linustechtips.com/topic/314015-airflow-layout/
How many fans can you have in the front? Just one?
I'm currently planning out, so it can change, but for now it's one.
https://linustechtips.com/topic/314015-airflow-layout/#findComment-4268580
2 in the front and 1 in the bottom - intake.
Put the PSU fan sucking air from the outside.
2 in the top and 1 on the back - outtake.
"an obvious supporter of privacy"
https://linustechtips.com/topic/314015-airflow-layout/#findComment-4268589
ehh..
i'm gonna put a 3.5" HDD, so one of the front intakes are going to be interrupted.
perhaps one less top outtake?
https://linustechtips.com/topic/314015-airflow-layout/#findComment-4268606
Put it in the 5.25" bays.
maybe i could buy an adapter.. thx!
https://linustechtips.com/topic/314015-airflow-layout/#findComment-4268640
Flip PSU around, have as many front intakes as you can fit. Leave bottom fan out (add later if you experience GPU overheating). Remove one of top intakes or flip rear top one as exhaust instead. Remember to have dust filters on all intakes.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/314015-airflow-layout/#findComment-4277124
