I built a computer it has a 970, 8350, GIGABYTE 970A-UD3P, 8 gbs of ram.
Im having problems with just about everything it wont connect with my NetGear N600 usb adapter, half of my usb dont work not even my front usb 3's work
I think im just gonna do a fresh install
one question do i need drivers for my mobo? what should i do?
https://linustechtips.com/topic/313800-help-pls/
Your USB jacks and your internet connection is far from "nothing works".
You need to use the disc that came with your wireless adapter to install drivers, or hook the PC into a router via ethernet cable and let Windows update everything on it's own.
Problem is I dont have a Disc Reader, nor do the back usb ports, I tried installing with the drivers on the website but it still didnt work
https://linustechtips.com/topic/313800-help-pls/#findComment-4265632
Might be worth it to snag an optical drive just to see then. I think they're fairly inexpensive.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
https://linustechtips.com/topic/313800-help-pls/#findComment-4265669
Nothing works is far from the truth.  It appears the only thing that isn't "working" is the motherboard.  And even then it seems to be a driver issue, rather than hardware.
Download the necessary drivers from:
http://www.gigabyte.com/products/product-page.aspx?pid=4717#dl<--Click this if your mobo is rev 1
or
http://www.gigabyte.com/products/product-page.aspx?pid=5194#dl<--Click this if your mobo is rev 2
https://linustechtips.com/topic/313800-help-pls/#findComment-4265670
or
what about the internet connection, I think i will just reset windows to ensure the everything works for once and for all
https://linustechtips.com/topic/313800-help-pls/#findComment-4265678
Resetting windows won't matter if you don't put drivers on the machine.  That's what you are lacking.
Use a different computer and put them on a USB 2, plug it into a USB 2 on your mobo, not USB3
https://linustechtips.com/topic/313800-help-pls/#findComment-4265692
or
this happened to me too. this is not drivers nor your windows . your motherboard is short circuit with your casing .
CPU: i7 4790K | Ram:Corsair Vengeance 8GB | GPU: Asus R9 270 | Cooling :Corsair H100i | Storage : Intel SSD, Seagate HDDs | PSU : Corsair VS 550 | Case: CM HAF Advanced.
https://linustechtips.com/topic/313800-help-pls/#findComment-4265710
Should I reseat the mobo
yes  do it and discharge your self before doing this . don' t stand on carpet with naked feet while doing this . put something non conductor betewwn your mobo and screws so they don't touch it directly .
https://linustechtips.com/topic/313800-help-pls/#findComment-4265747
ok, what did this do to help, what issue did it fix?
https://linustechtips.com/topic/313800-help-pls/#findComment-4265768
short circuit. everything will work after that if the mobo it self is not a faulty one.
https://linustechtips.com/topic/313800-help-pls/#findComment-4265791
Same thing happened with mine, except even internet didn't work, not a problem, just grade the driver CD, put it into my laptop, and copied everything on to a fresh USB drive, and put it in my computer it installed and everything was working, just had to get the rest of the drivers from the web
https://linustechtips.com/topic/313800-help-pls/#findComment-4265991
Can you please rephrase I cant understand what you mean
https://linustechtips.com/topic/313800-help-pls/#findComment-4266028
basically use another computer to a) download drivers from web site and place on usb to migrate to your new pc or B ) use another computer to move the contents of the cd to a usb to use on the new computer for drivers. one other thing is if NONE of the usb work get into to bios at boot and try setting to default that will usually clear the usb 2.0 to start working.
https://linustechtips.com/topic/313800-help-pls/#findComment-4266551
